1 - 2 of 2 Posts
J
Guest
I have been using me e-brake all the time ever since i got the truck and a few days ago, i push it down, it felt kinda soft, made no clicks, just went down like a clutch would feel and comes right back up like one as well... When holding it down, it does hold the truck but it doesn't stay held down...Could this be a linkage problem? Anyone help?
Make sure the pull handle to release the brake is all the way back in. Mannually pull it out and then push it all the way back in and try again. The spring on my handle is weak and if I don't do this it stays out about 1/4 inch and it does the same thing as you describe. If I manually push it in all the way it then works.
1 - 2 of 2 Posts
