The S-10 Scrub
I have dual exhaust coming out my rollpan, 3" tips, and it rattles like no other, i had door edging stuff around the holes, it helped a little, but that stuff gets heated up and its hard as a rock. Can ANYONE tell me what i can put around the holes, that is maybe soft and heat resist that i can bend and twist and stuff good, and where i can get it!!!! it would be highly appreciated. THANK YOU!!!
My suggestion is put another hanger close to the roll pan to help stop the rattle.
Buy some rubber hose cut it from one end to the other, then cut it to lenght.
Place the cut over the sheet metal all the way around.
Use a dremel tool and make the hole bigger.
It doesn't take much room and it will look good.
The Problem with adding another hanger or moving it closer to the hole is.
The exhaust moves separtely from the body that why they use rubber in the hangers, So even if you mounted the hanger to the roll pan it still going to bang around.
I have seen where they use a sheet of rubber.
Place it over the hole and cut out a smaller hole in the rubber tuck the rubber in the hole work the exhaust thru the rubber.
Then cut a aluminum sheet in the shape of the hole about in inch wide to hole the rubber gasket down and in place.
That also looks cool!
