1 - 20 of 22 Posts
2.2 Courtesy of Rascal
I was just curious for you guys who have dropped your trucks with springs/spindels if your trucks handling has been affected (negatively)? Everyone keeps telling me not to lower my truck because if the factory suspension. I wanted 3/4 but Les schaub ony has 2/2 for the x. I just dont know who to trust. Thanks for the input. Jered
Hey zigote do you have any pics? Does anyone know if les schaub will do the install if you bring the parts? Thanks again Jered
A Constant Work in Progress
zYgoTe said:
2/3 drop w/spindles and blocks. Mine handles better than it did stock. :thumbup:
same here.....i have a few pix on my site but they don't show anything great....if ya wait a few days i'll have some great shots of the truck on here....the ride is great....just be sure to cut the bump stop...there is a thread (i think it's in this forum and is a sticky) that shows how to do it....it's not too low but ya def. notice a difference...let us know how it goes.....late
xtreme nutcase
just be carefull when your cut your bumpstops. check for clearance before you do. i cut mine and my xhaust pipes are beating the hell out of my parking cable, and it's getting pretty close to the rear brake lines.
i had to move lines, then it was fine.
here ya go...there are some others on my site but for some reason when i upload em they get darker.....but maybe you can get some idea of what the 2/3 drop looks like
well the pix aren't showing up so ya will need to give the "www" a click....late
ok...here is a front angle shot....should be able to get an idea of what the 2/3 drop is like
back angle
Discussion Starter · #10 ·
thanks that helps a lot, oh and very sweet truck. The drop is just what I am looking for. Now I just need to find a shop that will do the drop. Thanks again
yeah...if ya know enough ya could do it yourself...the instructiuons that come with the spindles are pretty easy to follow.....the blocks are a no brainer.......have someone there with ya to help and ya shouldn't have too much trouble....late
Senior Member
yeah, i'm going to be doing my 2/2 additional drop on my zq8 as soon as i quit getting speeding tickets... damned ohio state patrol... the only thing that i'm somewhat concerned about is the whole spring compression step to remove and add the spindles... i have a coil spring compressor, but i'm just not happy/comfortable with it. oh well... :)
Primer Spots
keep a jack under the lower control arm, it will also help poping the ball joints in. The truck will handle great with the 2/3 I noticed a big improvement or maybe I just swing turns harder now that I know i can, even with the x cab feel like a heavy sports car.
Senior Member
okay, it must have been because i was reading a tutorial on dropping a stock s-10. :) they didn't already have the dropped coils installed. woops. :) well that makes it easier... about how long did it take any of you to do your spindles? what's this about cutting brackets?
Senior Member
oh by the way, 98 SS ON NOS, just wanted to say that you have a sweet a$$ ride and your web site was extremely helpful and interesting... i do have one question though, where did you get your ZQ8 wheels polished up and what the hell did they do to make them look that sweet!?!? thanks!
1 - 20 of 22 Posts
