DAILY DRAGGER :)
so im wanting to lower my blazer 5" in the rear. does anyone know if regular s10 leafs will work or blocks or what. the best i could come up with is 3" blocks from summit? i just wanna get that 5 in maybe 6
Hates 'know-it-alls'
83-94 blazers/jimmys use the same leaf springs as all 2wd s10s
95-97 use different leaf springs
98+ use yet a different set of leaf springs
so it depends on what year your blazer is, if it's the 96 in your sig for sale, then no you shouldn't use s10 drop leafs. The reason I say you shouldn't instead of saying you can't, is because you could use them. The differences between them is the lengths from eyelet to eyelet. If you use s10 leafs on a 96 then they will be longer than they should be and will push the shackles up against the frame.
