I have a 98 s10 with 139K on it. I have 2" spindles and want to go down another inch. Is it possible that the stock coils are worn and are already bringing it down some? If I use 1" coils will it make a difference then?
It is possible, but you should search ebay or a junk yard for a set of ZQ8 coils up front and leafs in the rear. That will give you about 1.5" of drop.
I've already got 3" drop leafs in the back so I'm gonna get 1" blocks for that.
Do you think I still fit 20's in the front without rubbing too bad (I already do) with 3.5" total drop in the front?
I have 4" in the front and bolted up a friends 18's with no problems. If you got a very low profile 20 it might work, but you'll have to measure to be sure.
