hey just wonderin what everyone has used and what had to be done to make it fit.
this is for a '91 s-10 reg cab short box with a turbo 350
my truck is identical and i had to have mine lengthened 2in i believe. i actually went and got a ex cab shaft and had it cut. to have it lengthened it costs alot more because they basically re tube it. i dont think it is neccesary though if you mount it back a touch. my motor sits perfect though. not a TON of room behind the distributer but its plenty and the th350 sits right on the stock crossmember with no probs.
Depends which tailshaft you have on the TH350. If you have a 9" you shouldn't have to do anything. If you have a 6", you'll probably need a 2-3" longer one.
lycan said:
I have a 1st gen short bed driveshaft that was cut for a th350 for sale. Someone else has dibs on the long bed shaft I have, but the short bed is still available. $45.
thats a dam good deal right there. it was over 250 to have one made for me...
