This is why I hate asking questions.
Should never hate asking questions
Cause some a$$hat has to be all judge mental.
No, that asshat, me, needs to know all the details before any help can be provided. Which, you still didnt do.
I didn’t ask the question for a grammar lesson.
I run my own shop, i work in the hsop during the day, and on a $400k racecar at night. I understand the 12 hour days and all that goes with it.
You asked for help, and didnt fully described the issue. Now here it is two days later, and we still dont know whats wrong because of the lack of info you have provided.
How did the drive shaft come apart? did the u joint break, or did the strap break? I also asked for pictures. Those help alot in many situations.
Do you know what u joint phasing is? that might be your problem, but i dont think so in a mere 10 miles of drive time.
Is your truck modified? Lifted? Lowered?
I hope you understand without knowing everything that is going on, and or happening, we are just guessing. YOU need to provide as much detailed info as possible.
Even right now, i think you pulled a rear and a portion of a drive shaft from a junk yard and stabbed it into your truck. I have nothing else to go off of, therefore cant really help.
When you put the wheels on, and it was still up in the air, did you put it in drive to see of the wheels 'rolled' straight and true? Thats an easy way to check for a bent shaft.
