Ok, guys once again i need you help.
1997 sonoma 5.3 conversion. current performance wiring.
The drivers side fender wire block(black rectangular piece with the wires and studs coming out) Its been 7 months since i took the fenders off and The harness is labled drivers side fender. It appears that it has 2 grounds and one power in it.
do these wires mount to this block (i would assume so) and if they do what order.
thanks in advance
They aren't grounds, they are fusible links.
Yes, they all connect to to that block.
No particular order, that is just a power distribution block. All of the studs will be hot when everything is connected.
Sdimess84
You nailed it Jared, buts your harness so of course you are. LOL
