hay uall will teh front drive shaft out of a 4door fit in a 2 door both 4.3 auto not sure of teh year on teh 4 door but is a square body teh 2 door is a 92
i saw what you did there!
look them up on car-part.com
its a good interchange manual
its the junkyards
its what they have and use
i verified @ work that the front drive shafts are the same interchange # between the 2&4dr models except bravada which has its own shaft
car-part.com is good for a general idea but not always accurate, its only as accurate as the person entering the info @ the j/y & i find that alot of them are idiots
i work @ a yard & i work with idiots, ill @ least tell you that i dont know & ill try to find the answer 4 u
Open mouth, Insert foot!
Bravada front shaft, transfer case and front housing are all shared with the Syclone and Typhoon.
Good to know if you blow a front diff in a Syclone, eh?
