H.D. & A. CEO.
This is for a buddy of mine. He broke the rear U-joint on his 2001 extended cab Sonoma 2.2 and bent the drive shaft. The only used ones we can find are for the 4.3. Will a rear drive shaft from a 4.3 be the same spline and every thing for the 2.2?
Thnaks for the help. Also have already called the dealer with no help there.
Thanks,
Verne
Wang!
Check out these guys... I bought all my driveline stuff from them when we put a TH400 in an LT1 Camaro... U-joints, rearend and rearend components, driveshaft cut to fit, and a driveshaft loop.
UNITRAX
