ok my rear U-joint went bad on me and i replaced it. i pulled the drive shaft off myself and had a mechanic change the u joint for me because i couldnt get the POS out. anyway i get it back and put the drive shaft back on, being careful to make sure everything looks aligned right. well i put the 4 bolts back in and now im getting a vibration. i looked at it again and everything seems to be in place correctly. anyone have a similar problem like this before? im clueless as what to do to try to fix it, and i really dont have the cash to bring it to a speacialist. is there anything i should look for or anything i should have done when i put it back on. thanks 95 s10 EXT
