1 - 16 of 16 Posts
· Call me Mario, Princess
I figured this would be a good place to post lengths of drive shafts to create a database to make locating a drive shaft easier and hopefully help people avoid having to pay to have one built. please add to the list if you have a confirmed application and length. If you have u-joint sizes that's a bonus. :tup:
85 Ford f250
front 34"-36" u-joints 1.125 od caps 3.622 outside locks
97 Chevy suburban
front 32"-33.5" u-joints 1.125 od caps 2.556 inside locks
rear 55" u-joints 1.125 od caps 2.556 inside locks
01 Honda passport
rear 40.5"-42.5" u-joints 1.062 od caps
83 Chevy suburban
front 27.5" installed length 32" with cv not sure on slip yoke range
rear 53"
04 Chevy suburban
front 30" no slip yoke
rear 54.5"
95 jeep grand Cherokee 32 compressed 35 extended including double cardan. 1310 joints
90 K1500 Reg Cab 8' Box V8 Np241 Rear Shaft 55"
02 Sonoma Crew 5.5" Box 4.3 Np231 Rear Shaft 53"
96-98 K1500 Front Shaft V8 NP241 collapsed 32.5"
00-03 K1500 Reg Cab 8' Box V8 Np261 Rear Shaft 57.5"
88-98 C1500 Reg cab 6' box V8 700R4 Rear Shaft 56.5"
96-98 K1500 Ext Cab 6' Box V8 Np243 Rear Shaft 65.5"
97 4door blazer rear 36.5"
I can supply lengths for specific driveshafts if there's A request. Our yard keeps measurements of driveshafts on file I should be able to supply. Our measurements are from weld to weld tho you didnt specify how you want them measured.
Found out today
1310 joints
Finally we have a thread for this. anyone have stock s series lengths? blazers, long beds, short box, etc. i see we got crewcab aready
first gen ford explorer (about 91) front driveshaft 29 3/4" compressed 32 1/4 extended, center of front joint to center of rear joint on cv
2002 zr2 blazer 2 dr rear driveshaft 29 3/8" outside locks on rear joint, not the nylon!
This is a great sticky. I myself just had to drop off a rear shaft to get reworked. Searched the JY's for a couple weeks and couldn't find anything close. Everything I did find was crushed/kinked from the fork lifts... But for $150 (shorten, new dust cap, 2 new joints), I would much rather pay that than have my shaft blow out the trans output. Going to try and make the front one out of some parts I have laying around.
See if people can start specifying slip yoke vs. slip shaft. Makes a big difference for guys not running a 231 or 241 with a stock rear yoke. And then for joint type specify double cardan, u joint, or CV; just makes it 10x easier to eyeball the list when you know what you are looking for. But I will add to the mix.
1979 Ford Bronco t18/205
Front: Double cardan, 1330 series, 25.875" C-C
Rear: Double cardan, 1330 series, 38.813" C-C
1 - 16 of 16 Posts
