I need help on finding the right downshift cable for my 700r4. i have a holley 600 4bbl carb and need to know what bracket and cable i need. i got a cable from the dealer but it looks like the wrong one. anyone have part numbers or descriptions. have everything in but this is slowing me down.
Trans
I used the cable from a camaro,and have a plate under my carb for the throttle and trans hook-up.I had to modify it a little to get the position of the TV cable right.You can use the original chevy brackets from another model and wont have to fabricate anything.look at the scrap yard.any model with 700r4 and carb will do.Summit sells a new bracket for the hollys and edelbrocks to get a correct hook up on the trans.MAKE sure you set the TV cable correctly!!!This is not a kickdown,it controls how much pressure you get it your trans.If not correct you will burn your trans up.
