I have several of the Bravada Double DIN Radio Brackets that can be used to convert a 1.5 DIN (1998-2002) to use a Double DIN radio and Bezel. They can also be used to make installing a Double DIN aftermarket radio easier.
Comes with all the required hardware.
$40 shipped to your door.
335075
Discussion Starter · #2 · (Edited)
Installation requires a bit of trimming to fit the bracket and radio, but that is how the factory did it with these brackets too.
Remove original bezel to expose the radio
335076
Remove the Radio
335077
Trim dash to clear bracket and install the J nuts into factory positions. Factory Bravada dash trimming and J Nuts shown below.
335081
Install Bracket using the J nuts and screws.
335082
Install factory Double DIN radio or aftermarket dash kit of your choice for a 2003-2005 S10/Blazer.
335083
time to get cereal
Thanks for that. I already have one of these brackets, it will make getting that double DIN radio delete into my 1.5 DIN dash much easier.
I initially got the bracket to help reinforce my dashboard since it no longer has the lower half.
Reactions: Harley
