1 - 15 of 15 Posts
I just installed a double din in my 2001 extended cab. I have about 40 years automotive technology experience and have installed a lot of sound systems in a lot of vehicles but until the past couple of years a really good kit for the 98–2001 S series was not available. I used a Metra 95-3027 dash kit, a JVCKenwood short chassis multimedia head unit, a wiring adapter and an antenna adapter. I made a go between harness so I could just plug into the factory harness.
It was a slam dunk and looks good.
347403
347404
before I had a single din which was installed with a scoche kit and looked like this
347405
I like the double din much better and have a lot of features that are like my new GMC.
the Metra 95-3027 dash kit is the least expensive way to install a double din. With a short chassis head unit you don’t have to cut the support in the dash. However you do not have a CD player with the short chassis units. This was not a problem for me as I have not played a CD in my truck in a couple of years. Much easier to use a USB drive or stream.
2004 Avalanche. 2001 V6 Extended Cab ZQ8.
Looks good. Any info on how it was painted, and what with. I like this bezel but I’m not sure about the black.
Get the double din bezel from 03 looks much better. Here’s my 2001
Sent from my iPad using Tapatalk Pro
Reactions: Frank Bukowski
· time to get cereal
That's a 2003 dash bezel you put into your 2001??? I have a 2001 sonoma and I'm looking to put foibles din into it what do I need to do please help
Yes it is.
1 - 15 of 15 Posts
