take off the license plate, then take out any screws that are in the holder, you should then only see tabs (as long as there are no screws in the tabs) it should pop off
wrong! the liscence plate holder is bolted on with the same bolts that are holding the airdam up. get underneath and pull the center two airdam bolts, and the whole thing will fall into your lap without even taking the plate off...but you will have two rectangle holes there fyi..lata bro
