1 - 13 of 13 Posts
We have one small ding in our passenger door. The paint is not chipped or anything. What do you have to do to get it out? Can you do it yourself? If not, how much would it cost?
Thanks,
twins0203
Try taking your door off, and setting it on the floor (On a tarp or something). Get a hair dryer or a portable heater and heat the area up on the bad boy up so it's warm to the touch. Immediately set 3-4 Ice Cubes (5-6 if you have an icemaker) into the ding. If by the time the ice melts it doesn't pop out, then try something else.
Does the ice pull the dent out? Heres a pic of the dent. Its not a very good pic but i guess it'll do.
Thanks,
twins0203
serious, you can't even see, it, what did you do to it? about that ice cube thing, that was the first time i heard of that, i would like to see the ice jump when/if it works.
Still plays with sparks
"Try taking your door off, and setting it on the floor (On a tarp or something). Get a hair dryer or a portable heater and heat the area up on the bad boy up so it's warm to the touch. Immediately set 3-4 Ice Cubes (5-6 if you have an icemaker) into the ding. If by the time the ice melts it doesn't pop out, then try something else."
Sorry about the poor quote, but that does work. Its not just the ice that makes it work though, thats only half of it. You neet the heat too. make it so its hot to the touch, not just warm. think about leaving it out all day in the sun and how hot it gets, thats about how hot you want to get it. and hold the ice on the dent, dont let it slide off. if it is simply a dent, it should come out, but if the metal has creased, tec term "reached its modulous of elasticity" its not gunna come out w heat & ice. You could also try taking the door panel off, heat the dent w/a heat gun and push it out from the inside, the heat will soften the dent and make it easier to push it out. good luck!
Jon
1 - 13 of 13 Posts
