OK, here's the scoop......had a stereo installed a couple of weeks ago in my 91 S10 4X4. Today while driving the stereo just stopped then my dome light would come on when my doors are closed and off when open????? I was told to check my fuses, all where ok.
Before I go and get soaked by some mechanic I'm hoping some of you guys might have some suggestions?
Thanks in advance.......
Ron
sounds like the dome light is being backfed by some other power or ground source. Pull the door pin and put a meter on it. I think on the 88-93 the pin is ground,so you should have 12volts at the wire. Did you have speakers installed? if you did find out if they pulled the kick trim. Had one once where when we put the screws back in we hit the dome wire(OOOPPPPSSS)
