Just Call Me Dick
my dome light will not go out. both of my door switches are good and my dim panel switch is off. i cant get it to go out with pulling the fuse. it is in my 86 jimmy 2dr. and since i pulled fuse for light my horn ,and lighter do not work. also with fuse pulled radio will not keep memeory (fixed that buy running new power wire to it) if some one could help me it would me much helpful
thanks, michael
to throw an idea out there...
maybe on of the doors "thinks" its open. check it the prod the usually gets pressed in when the door is shut is broken or something... not sure what to tell you man.
FLAVOR FLAV!!!
nah i don't think thats what it is. My truck does the same thing, as do many other s-series i know of. I just took the bulb out. My cousin's 94 did it and he said it was somethin in the switch, when he fixed his. I just haven't gotten around to fixin mine.
Just Call Me Dick
i fixed it! it turn out to be the switch in the rear was shorting out and causing the light to come on.all i did was pull wires out and put tape around them and it stopped
