Grumpy old bastard
Decided to go ahead and do a 350 in my 98 s10. Question is, I can't seem to find any info on a trans mount/crossmember for the project. I'll be usen' a turbo 350. Any help?
I used a 700 r4 and it bolted right tot he cross member. I don't know hwo the turbo 350 length is, but u should be able to use ur current cross member.
...Mark...
use ur original crossmember and just cut the lip off of it or order a book that u could use for the swap
Grumpy old bastard
I thought I saw somewhere an aftermarket one that had clearance on both sides so you can run pipes on each side.
