Useless posting member
do you need more than 8 vavles to do a dogleg? id say you need 10 tell me what you guys know.
PANFACE
no, you just need to have the right set up and 8 valves. the only reason you would run more than 8 valves would be if you have dual port bags, or air cylinders.
PANFACE
dual action cylinders? in that case, then if you did get 2 more valves you could dog leg, but only one corner.
get 4 valves for each cylinder and you could dogleg either side
