1 - 17 of 17 Posts
Wouldnt switching the cam out for a more agressive HP cam be a lot of help. I just cant find any on the net. any ideas?
The pimpdizzle
jbody performance has one but it just makes more power at higher rpms really.
Ross Racing Engines
STS Performance will custom grind one for you if you know what you need.
yeah, thats what i would want is more power at high rpms, cus im not really guna tow anything
AVTekk is my HERO
just curious why do you need another cam?
just lookin for power gains, it was just a thought
The doctor is in...
Comp cams will also custom grind you one. Personally, a cam will help; but there are so many issues with these engines that need to be addressed. If you really want power then you might want to look at porting the head, larger valves, true 1.6 rockers, and higher compression pistons. Then you custom grind your cam to match all of those factors and your desired goals for the truck.
Once you swap the stock cam and get a little taste for more power from a jbody cam (or another one) your going to want more. Internal engine mods are very addictive. :)
I totally agree. Head work, cam, and headers are the biggest bang for the buck in almost any engine.
Discussion Starter · #9 ·
ok, what would be the cheapest mod, i dont mean to be cheap, im just low on cash
Ross Racing Engines
e-fan...by far the most effective of the cheap mods
The doctor is in...
As far as internal, I'd say the true 1.6 rockers or porting the cylinder head.
Sik-98
e-fan and tb are the cheepest "noticeable" mods, both can be bought at a junkyard of certain cars. ive found that they dont make u much faster but they make pulling out into the fast lane a lot easier.
Discussion Starter · #13 ·
by tb do you mean a larger throttle body?
Ross Racing Engines
Yes, that's what he is talking about
Discussion Starter · #15 ·
ok, sounds like good ideas, thanx guys
im putting toghter a 2.2 right now with a custom cam that i had reground and it only cost around 150 or so. you just have to send them your cam. the place is calledSchneider Racing Cams really nice people anmd quick turn around time
1 - 17 of 17 Posts
