Do I need o2 sensors
732 Views 4 Replies 3 Participants Last post by  Rhotpursuit
I have a 97 S10 4.3. I don’t have a catalytic converter. The o2 sensor is kind of in my way is there any good reason not to cut out this section of exhaust and weld pipe in? The exhaust flange is bad and the bolts are broke this would be my easiest fix.
You didn't mention which engine you have or which O2 sensor you want to delete. A 2.2l has one in the exhaust close to the engine. A 4.3 has one in each bank of the exhaust. And they both have one after the catalytic converter.
Since you are talking about a leaky flange I'll guess the one you want to delete is the post cat O2 sensor.
You can remove it, but will likely have a SES light on all the time.
If it were mine I'd put on a new cat and a new ACDelco original equipment O2 sensor.
If the O2 sensor you want to remove is in the head pipe before the cat, it has to stay or the engine won't run very well since the computer will have no way of knowing if it is providing too much or too little fuel.
If you are in CA it would probably be cheaper to buy another truck.
It's the 4.3.
Reference another thread...day dreaming... 😂
