1 - 15 of 15 Posts
My 1/2, 5/8" tool doesn't fit so I assume it's a metric size. I can't get my fingers inthere to do any trial fitting. Anyone know the size offhand? Thanks much.
Boozebag
15MM baby.
A 3/8 universal joint and short 15MM socket on a long extension does the trick!
15MM baby.
Woopee , I will try that trick - thanks for the prompt response
I'll need the specific 15 mm dz wrench. I ground down a 15mm socket short but I cannot get it on the bolt.
Ok, I removed a bracket and was able to fit a small socket wrench and my cut down socket to loosen it. Thanks
Boozebag
^^ Huh?? I have several 2.8/3.4s and have never had to go through what you went through.
Wow...
Discussion Starter #9
Actually by removing that bracket, you can get a 15mm open end wrench on it which is how I tightened it.
I can usually get my hand down beside the engine and get a 15 mm ratcheting open ended wrench in there. I've only for enough room for one click though. It's not worth taking the coil and everything else out of the way. But if the engines hot I do get burned a few times on the air tube and exhuast. And with a 3 inch body lift makes it worse. I have to sit on top of the motor to get it lol
Sent from AutoGuide.com Free App
overthinker extraordinar
I always use a 15mm socket(3/8 not 1/2) next a swivel, and then usually two 3/8 extensions. I can get the bolt loose and out in about 3 minutes now. Any other combination I have tried is more difficult.
Boozebag
^^^ exactly what I do.
Am I missing something?
Must be too much beer..,
Maybe later.
I use a stubby combo wrench...lol
Awww..you ain't got shit!
I don't even recall using anything other than an extension and "maybe" a swivel. Been a while.
1 - 15 of 15 Posts
About this Discussion
6 Participants
jimmykicker
S-10 Forum
Full Forum Listing
