will detail for food
Looking at your slim/skinny air tank.
The picture looks identical to other online stores, yet your dimensions are different.
The one I am looking at on yhour site:
https://www.newmaticsinc.com/ProductDetails.asp?ProductCode=99940&CartID=1
It shows 21" overall length, 9.5" diameter
The other online stores show the same picture but with different specs:
Length - 34"
Diameter - 7"
Can you confirm the specs and get back to me? I would like to order from you, but I need the 7" diameter and longer length to fill up between my frame rails.
-Chris
I do renders!
It looks like a few other online stores have the wrong picture up...most of the other sites that I looked at and had the same product number (FST9243) were the same in dimensions. I'm sure Sunny can confirm but that's just looking at a few other sites..
Air Tank 5 Gallon 6 3/8"
ports, 2 1/4" ports & 1 1/8" port
21" overall, 9.5" diameter,
14" between mounting points
Newmatics
AJ is right I have a picture and description mix up. The tank you are looking for is Firestone 9248 slim and skinny tank. The dimensions are
34" overall,
7" diameter, 21.75" between
mounting points SLIM & SKINNY
I am about to change this picture. Sorry for the mix up.
