i have a 92 blazer with the digital dash gauges but my section with the spedo and turn signals went blank and are not working now, but the rest ofthe gauges are still working. how can i fix it?
Typically on the digital dashes develope the symptoms you means you have some cold/cracked traces on the circuit board... Pull the cluster, remove the PCB, and use a magnifying glass, eventually you will find them... simply touch a soldering iron to thm... or you can have it repaired at mrwhizzard.com
