1 - 2 of 2 Posts
digital instrument cluster went dark on '92 s-10 blazer. Does anyone have any tips on removing the cluster, especially removing the heater/ac control, having a tough time with it. Is there anything I can try without having the cluster repaired or buying a used one?
Will the mileage reading be lost once the cluster is disconnected
the mileage should stay the same.... it needs to have some type of voltage sent to the computer to shock/reset it i also had a hard time with my AC-heat controls dont remember what i did ...but i wasnt scared to tug a little (i think theres a coulpe screws here and there back there. theres a dude on ebay that sells them and repairs them ..but if its all out its not just the cluster there is something else try the power going to there (im sure you check but do it again THE FUSES) if your lucky it's a lose ground wire
1 - 2 of 2 Posts
