Are you suppose to use any type of sealant or teflon on the differential fill plug that is located on the rearend? I'm getting ready to fill my differential after it's been drained and wasn't sure if I need to put any type of sealant on the plug so it doesn't leak. Thanks.
not necessary... at the dealer we put a little bit of teflon tape on the threads to ensure no unhappy customers. i personally have never used it on those threads, until i saw people doing it. i never had a problem either way. just don't overtighten it... i've seen someone tighten it all the way in until it was almost fully inside the case...
