1 - 20 of 181 Posts
I has s475
I am basically writing this up to help some newer guys out here on the forum you can choose to sticky it if you would like. But basically this write it gonna consist of all the different type of drops, price ranges, different brand names and combination's. Anyone feel free to chime into this thread and post because i feel like I will miss a few things. I'm gonna write this up to the best of my knowledge and experience. This is just my way to kinda contribute all i can to the forum because it has help me out alot with many different questions and problems.
BTW I'M NOT POSTING ANYTHING ABOUT HACKING COIL'S OR HEATING SHIT UP NONE OF THAT SHIT IN THIS THREAD, THIS IS HERE TO EDUCATE THE CORRECT WAY TO EXECUTE A DROP.
****REMEMBER EVERY TRUCK IS GONNA SIT A LITTLE DIFFERENT, THERE NOT ALL 100% IDENTICAL FROM THE FACTORY.****
Different Companies
**NOTICE DJM,BELLTECH CAN BE PURCHASED ON SUMMIT AND STYLIN TRUCKS**
Suspension source http://thesuspensionsource.mybigcommerce.com/
Belltech http://www.belltech.com/
DJM http://www.djmsuspension.com/
Summit Racing http://www.summitracing.com/
Stylin Truck's www.stylintrucks.com
1982-2003 Stan. Cab 2WD
1/1 Drop
-1 inch spring's, 1 inch drop block
-1 inch spring's, pull a leaf from a stock leaf pack (you will prob wanna get a stiffer shock if this method is done.)
1/2 Drop
-1 inch springs, 2 inch drop block
-1 inch springs, 1 inch drop block and pull a leaf from a stock leaf pack (you will prob wanna get a stiffer shock in the rear if this method is done.)
2/2
-2 inch drop spindles, 2 inch drop blocks
-2 inch coils, 1 inch drop block and pull a leaf from a stock leaf pack (you will prob wanna get a stiffer shock in the rear if this method is done.)
2/3 Drop
-2 inch spindles, 3 inch drop block
-2 inch spindles, 3 inch drop leafs
-2 inch coils, 3 inch drop block
-2 inch coils, 3 inch drop leafs
-2 inch spindles, 2 inch drop block, and pull a leaf from a stock leaf pack (you will prob wanna get a stiffer shock in the rear if this method is done.)
-2 inch coils, 2 inch drop block, and pull a leaf from a stock leaf pack (you will prob wanna get a stiffer shock in the rear if this method is done.)
3/3 Drop (Cut bump stop's off, not recommend though)
-2 inch drop spindles 1 inch coil springs, 3 inch drop leafs
-3 inch drop coils, 3 inch drop block
-2 inch drop spindles 1 inch coil springs, 2 inch block and pull a leaf from a stock leaf pack. (you will prob wanna get a stiffer shock in the rear if this method is done.)
-3 inch drop coils, 2 inch block and pull a leaf from a stock leaf pack. (you will prob wanna get a stiffer shock in the rear if this method is done.)
3/4 Drop (May require drop shock's, and bump stop's will need to be cut off in the rear.)
-2 inch drop spindles 1 inch coil springs, 3 inch drop leafs 1 inch drop blocks, c-notch (not required but highly recommend)
-2 inch drop spindles 1 inch coil springs, 4 inch drop blocks (drop shocks)
-2 inch drop spindles 1 inch coil springs, 3 inch drop block and pull a leaf from a stock leaf pack. (you WILL need drop shock's for this method and a C notch)
-3 inch drop coils, 3 inch drop leafs 1 inch drop blocks, c-notch (not required but highly recommend)
-3 inch drop coils, 4 inch drop blocks (drop shocks)
-3 inch drop coils, 3 inch drop block and pull a leaf from a stock leaf pack. (you WILL need drop shock's for this method and a C notch)
4/4 Drop (Will need drop shock's and C notch)
-2 inch drop coils 2 inch drop spindles, 3 inch drop leafs 1 inch drop blocks, c-notch (not required but highly recommend)
-2 inch drop coils 2 inch drop spindles, 4 inch drop blocks (drop shocks)
-2 inch drop coils 2 inch drop spindles, 3 inch drop block and pull a leaf from a stock leaf pack. (you WILL need drop shock's for this method and a C notch)
4/5 Drop (Will need drop shock's and C notch)
-2 inch drop coils 2 inch drop spindles, 3 inch drop leafs 2 inch drop block's
-2 inch drop coils 2 inch drop spindles, 4 inch drop blocks and pull a leaf from a stock leaf pack.
5/5 Drop (Will need drop shock's and C notch)
-3 inch drop coils and 2 inch drop spindles drop shock's, 3 inch drop leafs 2 inch drop block's
-3 inch drop coils and 2 inch drop spindles drop shock's, 4 inch drop blocks and pull a leaf from a stock leaf pack.
5/6 Drop (Will need drop shock's and C notch)
-3 inch drop coils and 2 inch drop spindles drop shock's, 3 inch drop leafs 3 inch drop blocks drop shock's.
5/7 Drop (Will need drop shock's and C notch)
-3 inch drop coils and 2 inch drop spindles drop shock's, 4 inch drop block 3 inch drop leafs.
1982-2003 Ext. Cab 2WD
1/1 Drop
1/2 Drop
2/2
2/3 Drop
3/4 Drop (May require drop shock's, and bump stop's will need to be cut off in the rear.Carrier bearing x-member needed and set back plates) Carrier bearing
4/4 Drop (Will need drop shock's and C notch,Carrier bearing x-member needed and set back plates)
5/5 Drop (Will need drop shock's and C notch,Carrier bearing x-member needed and set back plates)
5/6 Drop (Will need drop shock's and C notch, Carrier bearing x-member needed and set back plates)
5/7 Drop (Will need drop shock's and C notch,Carrier bearing x-member needed and set back plates)
That is to the best of my knowledge i might have forgot some thing's so if you see something feel free to chime in. Also someone will have to chime in on 4WD's and blazer's because i do not have much knowledge on 4wd's nor blazers.
I have a 5/6 and I have a steep incline getting out of my shop and I do not need the carrier bearing xmember. I guess it would depend on what size rim you are running though. I am running 18/19 combo.
Whaaaaat no love for the 4x4 guys ?
Oh I see how it is.....
I has s475
I really don't know the different methods to lowering a 4x4 but if you would like to share im good with it. ;)
Banned
I am all against heating coils and don't ride on cut coils, but wouldn't pulling leafs be considered a hack too? Cutting coils increases the spring rate causing it to ride softer so would pulling leafs... right?
I has s475
Discussion Starter #9 (Edited)
Kinda in a way it could be seen as a hack because yes it does make your leafs lose quite a bit of stiffness, but by allowing yourself to run a stiffer shock such as a drop shock it would fix 80% of the softened ride.
Its not really perceived to be dangerous to anyone or anything as long as you put the leaf back together right and make sure everything is tight. But for example if your gonna pull more than one leaf or your gonna monoleaf it that's a hack and deam's it to be unsafe.
That's the way I look at it if anyone disagrees I would love to here your input.
No longer a pizza tech.
Leaf springs are different from coils. The spring rate isn't in the whole leaf pack its in each leaf separately. So by pulling a leaf you get a softer ride, which most people make up for with a stiffer shock or air shock.
cutting coils when done properly really isn't too bad. Just my experience
This is not a spring cutting thread. This is a how to drop using aftermarket parts thread.
And ross, i would add in the use of angled blocks, and add the jags that run website as well.
Cutting coils increases spring rate which in turn causes the ride to be more firm. Pulling a leaf decreases the load capacity, and softens the ride, nothing hack about it though. Just don't expect to be able to haul as much without helper bags or air shocks.
Its only hack when you remove to many, like all of them except for the main spring. Its basically too weak and can bend and cause problems.
I has s475
Discussion Starter #16
I have had cut coil's in my old s10 i have experience with them also, but this thread is to help with the proper way to drop your ride not the proper way to hack it to dog shit and make it unsafe. To often on this forum I find thread's with new guy's trying to figure out how to drop there truck's and people that don't know the proper way to begin with chime in and go "Hey brah why don't you just like umm cut your front coil springs in half and like umm monoleaf it then static dragzzz lawl." and that's not the correct answer at all. So if you could and are willing please keep the cut coils discussion out of this thread. Thank's.
And MO about time you chimed in on this thread i was waiting for your static knowledge to creep its way in here. If you see anything i left out please help add it in here, I think i touched base on all of it though.
Good chime in with info also Ryan always appreciated. Ill get going on the angled drop blocks vs. normal drop blocks article.
Thank's,
Ross
Banned
yea, i see no problem pulling a leaf, but riding mono is certainly a bad idea.
Ross, as much as I appreciate the time and effort that you put into this thread it's saddening that it'll will probably just get lost amongst all the other threads with great info. People can't even understand the search function let alone have enough brains to do a little research before making asinine threads.
I do like the thread though and agree with Ryan about the addition of angled blocks and these links...
http://www.jagsthatrun.com/S-10_Order.html
http://www.jagsthatrun.com/Pages/Parts_S10-PinionAlignShims.html
http://www.jagsthatrun.com/Pages/Parts_S10-301.html
http://www.jagsthatrun.com/Pages/Parts_S10-Heavy-U-Bolts.html
http://www.jagsthatrun.com/Pages/Parts_S10-Driveshaft-Align.html
http://www.jagsthatrun.com/Pages/Parts_S10-DrvshftKit-Short.html
I realize that just the one link would have sufficed but folks these days love to be spoon fed their info and there's a great deal of knowledge on that site.
Ive got something id like to ask might help a few more people out also.
But whats the best drop shocks to run? Ive heard some are better some are worse the normal shit. But whats the best in ones to run in your opinions Ross, Mo, Kris anyone else? haha
1 - 20 of 181 Posts
