2.2 flex fuel new fuel pump new fuel filter dies going down highway hard to start in morning
94 4x4,01 Blazer
2001 Blazer 4dr 4wd LT
what brand pump- and have you done a pressure test yet- check the sticky from Burned.
It's mostly BS
Also, what problems prompted the pump/filter change?
Same thing solved problem for a while havnt done pre test orderd pump off Amazon
Please use punctuation...and loose the text talk...if it's voice to text, it isn't working.
Sorry. Died going down the road. Changed fuel pump and filter. Solved problem for awhile.Dieing again. Acts like it's my fuel pressure regulator.But it's Flex fuel,doesn't have one.Thanks for any input.
It's mostly BS
Regulator is in filter.
If you could bother yourself to spend 10 minutes to give a detailed explanation of everything you observed and have done, then maybe we can help you fix it. "Died going down road" is worthless and no one cares enough to try to extract information out of you bit by bit.
