1 - 11 of 11 Posts
decided to go with the kumho ecsta stx. I am getting 255/55/16 my truck isn't lowered, I just want to make sure that I will not rub in the front at all. So If I should have any problems with regards to rubbing, or not fitting on the stock X rim let me know.
Discussion Starter #2
does anybody know if I will have any rubbing problems with 255/55/16 on my X rims? Need to know before ordering.
you should go with 255 50 16 that way it'll be the same height as stock about 26"
I am only going wider, stock in 235/55/16, i'm going 255/55/16
Sold
width affects how tall tires are to.
255/55/16 = 27.04"
255/50/16 = 26.04"
your stock 235/55/16 is 26.18"
best to go 255/50/16 but i wouldn't do it on the front since you have a x going to rub the inside of flares imo.
here is a good tire size calculator.
up to sumthing
i used to run 255/50/16s at all four corners
if ur at stock height they wont rub
but if u go lower they will in front on bumps & at full lock
Discussion Starter #9
see thats the problem, I checked tire rack and they don't sell these tires in 255/50/16. so I have to go 255/55/16. I need to know for sure if they will rub at full lock and on bumps? I really want these tires.
Black SS
My bro has those tires on his 24's, they seem good.
1 - 11 of 11 Posts
