61 - 64 of 64 Posts
I believe those are the correct ones. You should pull one of yours to compare to the pic.
Here's an endless discussion on swapping a 4l60E and a 4l80E. Of course it's written from the point of view for someone wanting to swap to the HD trans, but everything you could possibly want to ever know about switching their wiring is in it somewhere.
I stopped reading on post #145. Ignore any reference to a input speed sensor. The 4l60e doesn't have or use one.
Oldfogey47 when you did your drive by wire installation did you have to re-spice the wires back together between the throttle body and the tac module? If you did you might have mixed up the two gray wires one goes to the throttle body the other goes to the cruise control that may cause your issue. Pin 14 gray wire cruise on sw sig. And pin 5 is a 5 volt reference to throttle body .
Rectangle Font Line Parallel Slope
Font Rectangle Parallel Number Art
61 - 64 of 64 Posts
