I tried the "reset" process and there was some improvement. It would start and run, but not every time. I could tap the throttle when it was about to die and it would pick back up and run a bit longer. I could keep it running by doing this, but it still has problems and did not respond when the pedal was depressed.
I had my wife watch the TB plate and it opens slightly when the key is turned on and closes when the key is turned off, doesn't open with the key "on", engine off, and the pedal depressed.
AND, I picked up a P0740 & P0785 error codes to boot! Not sure what I'll do about them. They indicate trans. problems, but everything is new.
One step forward and two steps back!
Thanks...
