really easy....i can take mine off in less than a minute. the possibilities are kinda scary if you think about it. unscrew the two screws about the steering column, tilt the steering wheel down, if you have a floor shifter you're in good luck, if you have a column shifter, you may have to drop it into whatever gear is the lowest(maybe not), start on the outside edges and gently pull outward working your way poping the dash out from the middle too, grab the uppermost part of the pastic that is above the guages and pull that part out first while holding the emergency switch down with your other hand. you will need to hold this down the whole time you're pulling the dash over it cause it's pretty easy to break and very expensive to replace. you just have to work it around a little. once you figure out how to get it off once, you can do it a thousand times faster. i've taken mine out at a stoplight before.....not that you'd need to do that.
