well I just installed my 8.5 Superconductor wires and 5 NGK Iridium plugs...during installation of plug #3, the bastard cracked on the ceramic part and flaked off. So I had to reinstall one of the AC Delco Plugs. But I think I figured out how to properly install plug #3.
First jack up the truck so you gots plenty of room to work in the wheel well, lift the flap up, and slide on a 5/8" wobbly plug socket(heres the trick, remove the rubber crap in the center of the socket...removing it give the socket a better angle around the plug) you cant use a regular 5/8" plug socket...its too long, the one I gots is from Sears (p/n 43322)
one question, is it okay to use the old plug wire guides for 8.5mm Superconductor wires?
