Hola Bitches
I have a 99 s-10 ...and my dome light is weird *I think* ...when inside the truck...if I hit the dome override switch the light will not turn on. ...when the door opens it turns on and if I hit the switch than ...than the light shuts off. ..how can I get it so that the light turns on when inside the truck ...or is that how it comes ??:D gracias
I drive the short truck
ok when are you trying to turn on your dome light
while driving you have to turn up the roller next to the override button all the way up
for it to turn on when you open the door the dome override must be off
if that doesnt help try explaining the problem a little better
Hola Bitches
o ok so when I open the door and the light goes on the override is off right?
I Like Fire....HaHaHa
Correct.
Door open + Dome light on = Override off
Door open + No dome light = override on
Door closed + Dome light = Roller adjuster all the way up till it kinda click the notch
Door closed - Dome light = Roller adjuster is below indent notch and you're adjusting the dash light brightness.
Hit the dome override button 4 times in a row and you can turn the DHL off. Work also with the Trailblazer.
Hola Bitches
yea the DHL I bent the relay for that and than Im putting a resistor in the speaker grille sensor ...tahnks guys ...I thought it may have been Fed up
