1 - 2 of 2 Posts
Deadbeat
well i took the advice of 98 on nos and cut the brackets of the bumpstops in the rear off and it ride 100% better its so awesome! if you havent done this and you bottom out alot you should it rides soooooo much better i love it!.....i used a cutting torch and ground the sharp edges all the way to the frame with a cutting wheel then painted it but you can cut em off with just the wheel or maybe a good sawzall with a bunch of metal blades....and i bent the brake lines out from under the evap tank and i went over some pretty bad pot holes and it didnt bottom out....thanks 98 on nos! really helped me out!
1 - 2 of 2 Posts
