1 - 20 of 24 Posts
SOME ONE HELP ME HERE I AM UNDER STAND IT A LITTLE BUT DOES THIS MEAN I CANT PUT A SFA IN MY TRUCK, HELP
Sec. 14-137-25. Limitations
Each ``passenger motor vehicle'' as defined in subdivision (35) of
section 14-1 of the General Statutes operating on the highways of this state shall be equipped with a suspension system that complies with the following:
(a) Vehicle suspension configuration. Each motor vehicle shall be
equipped with a suspension system consisting of the basic elements originally provided by the vehicle manufacturer and geometrically arranged in accordance with the manufacturer's specifications. No suspension system component shall be replaced unless such replacement component meets or exceeds the quality and performance standards established by the vehicle manufacturer and the safe operating characteristics of the vehicle on which such replacement component is installed are not adversely affected by such installation.
(b) Height adjustment limitations. No additional devices shall be
installed or equipment substitutions made at any location on any motor vehicle when such installation or addition either:
(1) Raises the sprung portion of the vehicle in excess of four (4) inches
above the vehicle's unladen height as established by the vehicle manufacturer;
or,
(2) Lowers any part of the sprung portion of the vehicle so as to reduce
the vertical clearance, between the sprung portion of the vehicle and a level surface on which it rests unladen, to less than four (4) inches.
(c) Spring replacement limitation. No suspension springs which have a
load carrying capacity or spring rate below that specified by the vehicle
manufacturer shall be installed on any vehicle.
(d) Shock absorber mounting limitation. No shock absorber shall be
installed in any manner which will allow it to reach its extreme stroke
limitation while the vehicle is being operated.
(e) Tires - Limitation. All tires on the same axle or on axles which are
less than six feet apart must be of the same tire size with respect to diameter and maximum width. Each such tire shall have a load carrying capacity specified
by the tire manufacturer in excess of the intended maximum axle load divided by
the number of tires on the axle. Federal Motor Vehicle Safety Standard No.
571.109 shall apply in establishing the load capabilities of tires.
(f) Wheel track distance. No modification of a vehicle suspension system
geometry shall result in any reduction of such vehicle's wheel track distance
Depends on if it will raise your vehicle more tha 4 inches or not...
If not I dont see why you should have a problem
Jeeps have solid front axles and they arent illegal. I think a SFA would meet if not exceed factory standards. As far as the 4 inch lift part. My friend has an 8 inch on his cheerokee with big tires, I forget how big but, he just got pulled over and the cop gave him a warning and told him that he was 1" under the legal height limitation so i think anything under 4 would be fine. I dont think you should have a problem.
Yea...look at my location...Milford,CT
S10Blazer96 said:
SOME ONE HELP ME HERE I AM UNDER STAND IT A LITTLE BUT DOES THIS MEAN I CANT PUT A SFA IN MY TRUCK, HELP ........
there you go. sfa swap meets and exceeds quality and performance standards but it doesent say on or off road if you want to get tricky with it :D
Malice said:
yo lucky dime what year s-10 you got im from ct also, stratford
89 S10 Blazer...Where abouts in Stratford?
Hmm, Im not too familiar with startford. Only places in stratford. Like Vintage Racing, Ubertis, Lordship area, and some other places.
you know the devon bridge and if you keep going youll hit wall mart and home depot well if you keep going like 3 mins i live around there
Yea I know exactly where that is...Up around Vintage Racing Services right?
dotn know exactly where that place is but yea if you know where the walmart is then im in that area like 3 mins from there
Cool...Yea I know where that area is.
Discussion Starter #20
WELL THANKS GUYS NOW THAT WE ALL KNOW WHERE EVERYONE LIVES. pyro so you think it would be legal to do or not, i really dont know what it means and what i can get away with. thanks for the help
1 - 20 of 24 Posts
