Gerald said:Also, how did chevy lower the trucks? Spindels or springs, drop leafs?
Thanks.
:stupid: also the drop is 1.5 inchs front and rear . but with this tire and the zq8 package its more like 2" drop front and rear00IndigoX said:235-55-R16
litestab said:will my tires rub if i put a 2/3 drop on my x
they will only rub the fender flare lip. after you lower it or before you put the tire one trim the fender flare lip back somelitestab said:will my tires rub if i put a 2/3 drop on my x
chevy lowered the truck by de-arching the leafspring 1.5" and the front the used 1.5" drop coils and the zq8 or xtreme tires are .5" smaller than regular s-10's tires...Gerald said:Also, how did chevy lower the trucks? Spindels or springs, drop leafs?
Thanks.
WRONGxtreme-10 said:chevy lowered the truck by de-arching the leafspring 1.5" and the front the used 1.5" drop coils and the zq8 or xtreme tires are .5" smaller than regular s-10's tires...
All that= 2" drop :yikes:
xtreme
that is what i said only in the way it was supposed to been said.The zq8 leaf pack is a stock normal leaf pack [4 leafs] with the top leaf pulled which gives the zq8[3 leafs]98lows10 said:the normal S10 leaf pack has FOUR (4) leafs. and the ZQ8/Xtreme has only THREE (3) leafs. and a 1.5 drop coil in the front. then bigger front sway bar, and a rear swaybar(some with bumper shock)
