Thump Thumpin' Member
why is my glove box door a piece of sh*t , i have to slam it a bunch of times to get it to stay shut. Anyone else have this problem?? i have a 2001. I Thinkg its because if my bass shaking it loose but im not sure, plus im under warranty still, should i take it in or what????
Thanks for any help
Travis
Check the mechanism that makes the door lock. You will have to take out about 7 or so 7mm screws from the inside of the door. The whole box area will come off and the handle mechanism will be detached. Mine was doing the same thing and it was because the spring that slides the bar over wasn't pushing it far enough. I had something on the bar. I pushed the bar by hand and that fixed it. Put it back together and no more problems.
Try that! Takes about 5-10 mins to take apart and put back together and you don't have to remove the door.
