Have 2001 w/2.2l died on road has spark, has between 55 and 60 psi fuel pressure, replaced crank and cam sensors, no coolant in oil or vice versa, battery replaced, no security lights on no codes any ideas out there for me to try need help please.
94 4x4,01 Blazer
2001 Blazer 4dr 4wd LT
check fuses- ecm,ecm 2- if blown- you will need to follow the wire harness from underhood fuse panel around back of engine- you are looking for melted wires- seperate and reinsulate (liquid electrical tape(H-Depot).
It's mostly BS
Try starting fluid to check fuel system function. Also, could have jumped timing chain, check compression.
