Accessing Cowl Plenum (L and Central Portion)
There has been a significant pause in this project, including documentation of last work completed. I will try to accurately recount what I did last.
Removing remaining items to create access to Cowl Plenum.
Removing Windshield Wiper Arms. Remove the semi-flexible, black Wiper Arm Covers. If necessary, review the photo to understand how they are attached. Remove the M8-1.25 hex nut (13mm) for each arm, and carefully pry the arm off the tapered, knurled, Windshield Wiper Transmission shafts (spindle). Sometimes rocking back and forth is necessary to break them free. In rare instances, you may need a puller tool.
Removing Air Inlet Grille Panel (Center Cowl Panel trim). Remove 2 – M4.2-0.79 x 17mm 12mm washer SEMS (7mm) and 5 - push-type retainers. Note: the 5 - push-type retainers utilize a plastic screw with a Phillips head for the “nail”. Just pry them partially out of the retainer to collapse the retainer and allow it to be removed. Remove the Panel.
Removing Wiper Transmission. Remove 3 – M6.3-1.69 x 20mm 17mm washer SEMS DST (10mm) at both Wiper Transmission shafts. Disconnect Transmission from Wiper Motor. The Transmission Linkage Bushing will “pop” off the ball on the Motor actuating shaft, possibly with prying. Be careful; AFAIK, replacement bushings of good quality are not available apart from purchase of a complete transmission. Go ahead and remove the 3 – M6-1.0 x 29mm countersunk hex bolts (10mm) mounting the Wiper Motor. This allows the Motor actuating shaft to be shoved out of the way for Transmission removal; same with the bolts while working on the sealer later. Work the Transmission out of the Cowl Plenum. While removed, check each spindle housing for free rotation. They sometimes bind, causing the Wiper system to fail. Unfortunately, I do not believe the spindle housings can be reliably or easily disassembled without damage for cleaning, rust removal, and lubrication. I disassembled and reassemble one. It was not “pretty”. However, there is plenty of free volume around the middle of the spindle shaft inside the plastic housing for injection of grease with a needle tip if you are inclined to drill a small hole through the housing. There are bushings on both the “top” and “bottom” of the housing.
Removing remaining obstructions to Cowl sealer access. There are a variety of fasteners that likely still protrude into the Cowl Plenum. I am not listing those additional I removed to improve access and decrease scratches/cuts to hands and arms. Remove what you deem appropriate.
Windshield Wiper Arm Cover removed. Yellow circles show small, retaining tabs.
Push-type retainer removed from Air Inlet Grille Panel.
Remove these 3 – Dual Spaced Thread (DST) SEM screws at both Windshield Wiper Transmission shafts.
Windshield Wiper Transmission pried free of Motor.
Windshield Wiper Transmission removed from Cowl.
L side of Cowl Plenum. Surface rust on left (in photo) is forward of the Instrument Cluster in the Cab. Sealer to be replaced is bounded by yellow lines. Red circle is Cowl Plenum Drain L Outlet. Blue circle is mounting location for Windshield Wiper Transmission L Spindle.
Some of the seam sealer (in green) between the Cowl and Firewall. Red circle is a work light inserted from the cab interior, through the opening for the Air Intake Assembly.
