I
icerain
·Guest
first can you put two subs in the same box. I mean can you mount them in the same box sharing the same air space.
second Ive seen some subs mounted the magnet out side the box and the front facing in. What does that do and can that save space or does it require the same airspace as if it were mounted normal
Im trying to find a way to mount to alpine tens in my standard cab 91 and I have zero room behind the seats and can't give up any clicks so I wanted to make a center consol or have one built to hold both subs and my switches I figure I can mount the amp to the back of the cab behind the seat
