I have a 92 Slonoma with a 4.3 and the 700r4 trans. I changed out the
oil and while I was at it installed a shift improver kit from B&M along
with a deep sump from TCI..All went good save for the TCI sump as
I had to shave some of the front area where it butts up against the
inspec plate/box.
Here's what I have. According to the instrucs from B&M as well as the
manual it's stated that the TV cable housing has to be brought all
the way rearward to it's stop by pushing down on the lock
tab. Then when it's all the way at the stop, open the throttle all
the way as the cable inside can ratchet up so the play is eliminated
where the cable hooks to the throttle valve linkage in the trans..
I went to the TV cable on the throttle bracket and there is NO tab,
and the TV cable housing appears to be a no-adjustment type where
there's supposed to be the push down tab..I noticed when I was
double checking my work that there was some play at the linkage
to plunger in the trans, but not much. The hook went into the linkage
like to was suppose to.
Where's the adjustment for the TV cable ? I 've looked all over the TV
housing and throttle bracket, and at the other end of the TV cable
where it goes into the trans..No adjustment..
I don't want to screw this trans up because I didn't get this Throttle
Valve and Throttle Valve Cable adjusted right...
Any help or info on this please..Thanks bg
inspec plate/box.
