1 - 20 of 25 Posts
My dad & I just put corvette servos in both our trucks ('93 S-10 & S15). They made a huge difference in shifting. I recommend this to anyone with a 4L60E or 700R4. You can get them from www.pro-built.net for $20.
2 Litre Terror
You sure thats a 4L60E. I bleive you mean the 4L60. The e version is electronic and the vette servos don't work in them. JFYI
want my #... 911 beotch!!
damn, i was a lil excited till i red 02redblaze's post. oh well, my B&M Shift Plus works pretty damn good anyway.:thumbup:
2 Litre Terror
Im 99% sure that it wasnt until like 94 or 95 that the E's came out. Waitin for the shift plus for mine. How hard is the shift? Hard enough to bark second?
Yes I'm sure its a 4L60E & yes the corvette servos do work in them. JFYI
Not to flame anyone, but where do you get your information? 99% sure? Try reading a book sometime.
I have a B&M ShiftPlus too.
Witch servo is it? The one inside or the one on the side of the trans?
2 Litre Terror
Hey wise ass, if ya didnt want to flame why get so dicky.. After eading my books:finger: I found something that maybe you should have to....Your truck was a midyear production as some 93's had 700r4's in them. perhaps you should have all info straight first. After 94 the servo doesnt do anything. 94 and up has to be programmed directly from the Comp. Also, all the servo does is raise shift point..does nothing for or power.....The difference you feel is 90 % the B&M not the servo.Sorry I'm not as book smart as you seem to be.....I'll try harder:wtf: Oh yeah just so you know, that will wreak havoc with the Valve body bore in about 30,000 miles....why spend that money on just a servo when a full transpak for $60 bucks for that tranny wouldhave given more benefits...Oh maybe I should check my books on that one....... Im done..... When people just try to help and your a DIICK, sometimes it makes you look worse. Everyone likes a piece of ASSS noone likes a wiseasss
4-Door Blazin'
No need to :argue:
Derrick dood, you got burnt, give it up and go play with your servos. :booty:
not to be a dink,
but by changing the 4l60e servo to a vette style one youre changing the surface area of the piston and it allows the band to apply qiucker 0n the 1-2 and 3-4 shifts. w/ a shift kit you will get better shifts in all gears on top of the servo addition.
also the servo has do direct affect on the valve body bores been worn . the tcc and actuator feed limit valves are the ones that usually wear out and they dont share the same same oil circiuts as the servo.
where did you get that info ?
2 Litre Terror
GM TSB on signs of abnormal wear on Valve body bores from factory or aftermarket servos....Just tryin to help.....
Discussion Starter #13
Wicked X - Its the servo on the side of the trans.
02RedXBlaze - Let me state some points that you are wrong on. My truck does have a 4L60E, the corvette servo does work in it, & it did not raise my shift points.
This thing did made a huge difference in my '93 4L60E even with my ShiftPlus off.
2 Litre Terror
Derrick take a chill, I never said it didnt, i questioned wether it did or didnt. its very easy to confuse the 2 tranny's. second. good. glad it worked. Didnt say it wouldnt work in that year. Its after 94 that I was stating and as far as shift points go i was talking about part throttle shift points. Geuss I was wrong on everything though.. Im done...time to unsubscribe...
Afterhours Admin
i have a corvette servo in my 94 SS. also a b&m shift kit. sitting behind a LT4, the truck will bark 3 gears at 1/2 throttle..at 2000 rpm, the 1-2 shift hits so tight that it feels like the rear is gonna fall out...lol
avtekk didn't we talk about the corvettte cervo at the last meet at kop hooters. anyway, i sent my money in for mv 2 nights ago
how hard is it to put in that cervo derrick?
Afterhours Admin
its spelled servo dammit! heh, yeah, it was broght up, but we didnt discuss what it will fit into....
1 - 20 of 25 Posts
