Good looking truck, Jay. Looks a lot like mine.
Thanks, I noticed the resemblence, I thought I'd put that picture up to give you an idea of adding some more smoke to your avitar
I used a relay wired to key on power for the fan. For the condenser I used one out of a '95 S-10, it's designed for 134a, it uses metric fittings so I had to make some custom hoses and liquid line since the rest of the donor a/c was SAE.
Now, the truck originally had only heat, being in Florida I got the a/c stuff and removed all the vacuum doors and controls and set it up to run on max a/c, it would turn on with the a/c fan switch and used all the fan speeds.
I converted the truck to V-8 first, then added a/c, the radiator was moved back a little, it was no longer in the forward position, kind of in between forward and stock.
It was cold as hell running at 20 mph and up, 41 degree vent temp on a 95 degree day.
But as soon as I slowed down the engine would get hot and the a/c would stop blowing cold.
Maybe a cowl hood would allow more hot air to escape.
But instead I took the a/c out.
For the fan, the taurus fan is offset a little to one side, there are other cars that use the fan in different shrouds.
Here are some pics of the truck You can see the fan installed. There are few pics because I traded the truck and don't own it anymore, I do have pictures of it with a/c installed that I might put up on the site along with some others since people on this site might want to see them.
