Thanks, but sounds like that is the one for the gauge.I need the one for the pcm,for the fuel air.
What year?Where is the coolant temp sensor on as10 2.2 .How many are they.My temp gauge reads good.Just acts flooded after it gets warm and sits around 45 mins.
Thanks
2000 S10 Truck. Had this truck a year,and trying to make everything right.Slot of thing were mess up.What year?
I could he wrong but I believe it's a 3 wire sensor. One signal goes to pcm, one to the gauge. So it's one sensor sending 2 separate signals. Which is why your gauge could be correct while your pcm is not.Thanks.If this is bad why does the gauge read good?
Who said it was bad? Pretty uncommon... the computer uses its reading to operate the gauge.Thanks.If this is bad why does the gauge read good?
You are wrong... I literally just posted the pinout of the connector.I could he wrong but I believe it's a 3 wire sensor. One signal goes to pcm, one to the gauge. So it's one sensor sending 2 separate signals. Which is why your gauge could be correct while your pcm is not.
Yeah, I saw, but the one in my truck is still a 3 wire. If you check rockauto both a 2 and a 3 wire are available for the 2.2Who said it was bad? Pretty uncommon... the computer uses its reading to operate the gauge.
I really hate misinformation being spread 'round these parts. So please, tell me which one of these sensors for his truck has 3 wires.Yeah, I saw, but the one in my truck is still a 3 wire. If you check rockauto both a 2 and a 3 wire are available for the 2.2
I wasn't attacking you, dude. Chill. We're all here to learn. Obviously you've been around for over a decade working on these and not everyone knows every nuance about what stuff GM decided to randomly change year to year. I wasn't trying to spread "misinformation" just adding to the conversation. The AC Delco 213815 that's in my truck is a 3 wire. I didn't know if he could have had that style or not. I'm not surprised that the obd2 vehicles are different which is why I said "I could be wrong" thanks for the clarification.I really hate misinformation being spread 'round these parts. So please, tell me which one of these sensors for his truck has 3 wires.
2000 CHEVROLET S10 PICKUP 2.2L L4 Temperature Sender / Sensor | RockAuto
RockAuto ships auto parts and body parts from over 300 manufacturers to customers' doors worldwide, all at warehouse prices. Easy to use parts catalog.www.rockauto.com
