1 - 12 of 12 Posts
Aside from a blown head gasket, cracked or warped head and a cracked block, is there any other way for coolant to get into the cylinders?
I cleaned up the block, had the head decked, pressure tested and replaced the head gasket. it's still burning coolant. I didn't see any visual cracks in the cylinders, so I'm just wondering if there is another possibility of coolant getting into the cylinders.
Mr Goodwrench's Evil Twin
What makes you think you're burning coolant? When you said you cleaned up the block... what exactly did you do/use to accomplish this? Did you check the block with a straight edge? Was the surface of the block pitted at all? Did you use a multilayer steel or composite head gasket?
Discussion Starter #9
Lots of white smoke and liquid coming out of the tail pipe along with the coolant level dropping.
I used a razor blade, scotch bright pad and a scotch bright type wheel on a drill.
I don't have a straight edge and there was very minor pitting.
I used a composite gasket.
The block may very well be the issue. I just wanna make sure there aren't any other possibilities before I pull the engine out.
time to get cereal
Did you use new head bolts and torque them properly?
The egr plate gasket on my 1995 2.2l failed leading to a cracked exhaust port on no 4. Replaced that cast iron plate gasket twice thinking i didnt clean it off good enough because of its location behind the head. Still was leaking coolant out the tailpipe. I of course had to repalce the head. That was a PINA.
That EGR plate has 2 different versions. If you have it on yours I'd check to see if it's cracked and has the right gasket installed.
I use Permatex Copper gasket sealer on both sides of that gasket now. Also use the solid felpro head gasket orange/brown colored. Works perfect every time.
I'd pull the head to check for sure. I've also reused the ' stretched headbolts with no problems.
1 - 12 of 12 Posts
