Hi,
I was wondering what discs from the junkyard would be an easy swap. I was thinkin a setup up from the third gen camaros?
want my #... 911 beotch!!
how bout swapin in some discs from a same year 4x4 s-10? would that work? and are the front discs on a 4x4 bigger then the 2wd?:confused:
Only problem with that is you won't have backing plates to mount the calipers to on the back. Good idea, though.
you can pick up Camaro rears for 250-350. Then you could sell what you don't use. It will probably have a posi in it and some decent gears. They will be worth around $100. Then sell the axles and housing for a little and you have made some money. Or, better yet, put your drum setup off your truck on it and sell it as a complete Camaro bolt in differential.
Sorry, I always try to figure out a way to make money from the extra parts I have to counter the initial cost of the part.
good idea, i try to do the same:thumbup:
