can i use the DJM 3"drop control arms and 3" drop coils or do i have to use the stock springs for the control arms to work
s-series #2?
yes. drop control arms are only reccomneded for stock springs and spindles.
just do coils/spindles
Hates 'know-it-alls'
drop control arms suck ass, I recommend not using them. Basically if you run them, you are limited to only dropping the front 3". Another reason they suck is because they hang down really low (3" lower than the stock ones) and can get hung up on bumps and stuff in the road. To answer you questions though, if you run drop control arms it is recommended that you run stock coils and stock spindles.
ok cool cool thanks gusy im just going to get 2" drop spindles and 3" drop coils
but im looking to go 6" in the front do you know any way to go with a 6" drop with out cuting coils
